BMRBOI 8 Report post Posted August 30, 2012 What do you guys think of this? It says 1994 but its a 1992 going on production date. Being a jap import would it have the jatco transmission? Kms to high? What you guys reckon its worth? Trademe Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted August 30, 2012 yes will have jatco . non vaons m50 less low down torque red fades badly better to buy this one lower k's , auto works fine. http://www.bimmersport.co.nz/forums/index....showtopic=40806 or this one with 5spd then no trans problems http://www.bimmersport.co.nz/forums/index....showtopic=41312 have other 17" wheel options availible Quote Share this post Link to post Share on other sites
Allanw 1075 Report post Posted August 30, 2012 What do you guys think of this? It says 1994 but its a 1992 going on production date. Being a jap import would it have the jatco transmission? Kms to high? What you guys reckon its worth? Trademe Weird, registered as a 1993, advertised as a 1994, it's a 1992 model (according to the Vin on the plate anyway). It's non-vanos, so has to be pretty early, and the odometer history doesn't make sense, and isn't really explainable with the normal reasons of entry error etc. If you ignore the two low readings, then the car only did 252 kms in 2 years. Why are the TWO low readings there, and why was it almost parked up for 2 years? Apparently it's on bitsteins and has a M sport ECU..... Quote Share this post Link to post Share on other sites
BMRBOI 8 Report post Posted August 30, 2012 (edited) How tidy is that manual one Brent? the gf wants one which isnt to ruff. The red one looks pretty tidy, leather interior etc and i reckon i can get it for 3g. yes will have jatco . non vaons m50 less low down torque red fades badly better to buy this one lower k's , auto works fine. http://www.bimmersport.co.nz/forums/index....showtopic=40806 or this one with 5spd then no trans problems http://www.bimmersport.co.nz/forums/index....showtopic=41312 have other 17" wheel options availible Edited August 30, 2012 by BMRBOI Quote Share this post Link to post Share on other sites
BMRBOI 8 Report post Posted August 30, 2012 Weird, registered as a 1993, advertised as a 1994, it's a 1992 model (according to the Vin on the plate anyway). It's non-vanos, so has to be pretty early, and the odometer history doesn't make sense, and isn't really explainable with the normal reasons of entry error etc. If you ignore the two low readings, then the car only did 252 kms in 2 years. Why are the TWO low readings there, and why was it almost parked up for 2 years? Apparently it's on bitsteins and has a M sport ECU..... I dont believe this m sport ecu lol, bilstiens i wonder if its the yellow type with the dust cover. On ETK it says it was produced in 03-03-1992 makes it older then my 1992 325i. Thats quiet early for a coupe to be produced huh, i always thought they weren’t officially produced as coupes until 1993. Quote Share this post Link to post Share on other sites
