euroriffic 620 Report post Posted September 1, 2012 After a pair of front strut tops to dial in abit more camber on the front of the touring to bring the wheels in abit. TIA Quote Share this post Link to post Share on other sites
thorburn 121 Report post Posted September 1, 2012 You'll need to get m3 evo strut tops and switch them from left to right. There are other ways of gaining camber for fitting wheels. Fitting washers (shims) between the strut and hub will gain more camber. It will also create a larger scrub radius Quote Share this post Link to post Share on other sites
euroriffic 620 Report post Posted September 2, 2012 I was thinking of doing the washer trick but thought I should do things right. Or maybe I should do it... Will save me abit of coin... Quote Share this post Link to post Share on other sites
