adrianloo 0 Report post Posted September 4, 2012 Hey, I have a 1981 318 bmw and the water pump is leaking and sounds terrible. I am new to owning a bmw and am wondering if someone could help me with what I need to replace it with. Do I need to get another one specific for this model or will a water pump out of a newer 318 fit? I am a student so looking to replace with the cheapest option. Thanks, Adrian Quote Share this post Link to post Share on other sites
adrianloo 0 Report post Posted September 4, 2012 It sounds like the bearing is rumbling. The fan has some play in it and the water appears to leak out from behind the fan when I wobble it or push it so it is not straight. Does this sound like I need a new water pump or just a new bearing? Thanks, Adrian Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 4, 2012 You will need a new pump. Try our sponsor http://www.bimmersport.co.nz/forums/index....showtopic=10481 Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted September 4, 2012 (edited) You will need a new pump. Try our sponsor http://www.bimmersport.co.nz/forums/index....showtopic=10481 recommended! a water pump from an early E30 318i (m10)will also work. and definatlely doable yourself if you know a ratchet from a screw driver Edited September 4, 2012 by _Ethrty-Andy_ Quote Share this post Link to post Share on other sites
