Forrest
FS: E30 325i Coupe
Hey everyone,
New car means this one has to go. I have owned this for 3 years, it has had several bimmersport owners before me. In my ownership I had driven about 25,000km in it (including two track days) for the last 18 months it has been driven basically everyday.
1985 BMW E30 325i Coupe
Pre-facelift
NZ New
Factory manual
Platanengrun Metallic (only seen two or three in this color)
325,000km
Specs:
Electric sunroof
Motorsport Recaro seats with vinyl bolsters (fabric is wearing a little thin in places, but still tidy, rear seat has a super glue stain on the bench)
Tech 1 wheel with new emblem and motorsport 5 spd gear knob
Race series spec Koni adjustable shocks front and rear with matched race series spec king springs front and rear
Urethane: control arm bushes, trailing arm bushes, diff mount bush, front sway bar mount bushes, steering coupling, rear sub frame bushes
3.64 LSD with replaced front oil seal and rear gasket seal
180km facelift M20 motor conversion with face lift gearbox (15,000km ago it had: plugs, oil, water pump, thermostat, all the main cooling hoses, cambelt and tensioner, rear main seal, rocker cover and sump gasket, exhaust manifold gaskets, distributor rotor and cap, set of good leads all replaced at once)
Custom exhaust (2.5inch with a bullet resonator and a high flow muffler at the end (loud but sounds gorgeous)
Electric fan only on a switch not a thermo switch
Z3 shifter with new plastic cup bush and brass bush upgrade
Trusting race brake pads
E36 window switch conversion
Bottle caps have two near new tyres on the rear and the front have heaps of tread
The good:
180km facelift M20 motor is a peach, had most bits and pieces refreshed 15k ago, plenty of power and smooth
Most of the parts on this car have been replaced, adjusted or upgraded
Handles like s**t on a blanket, can't buy anything as fun for less IMO
The bad:
Gearbox is a little winey but shifts perfectly fine, brought from Kerry at Mosens (member on here)
Needs a new front windscreen (can provide for purchaser)
Rego runs out on 14th of October
Rust on the roof and rear quarter will need fixing before a new warrant (was borderline last time)
Rear sub frame bushes do need replacement
Needs a wheel alignment (can sort this for the purchaser if needed)
The drivers door has a decent fist sized dent in it, would not be hard to pop back out fill and paint
This car would be perfect for someone looking to buy a great track day car of which someone has done all the hard work already and installed all the good bits to make it drive brilliantly. Just add a set of 15 x 7 wheels and some semi slicks and your away. Or add a roll cage and the other bits and your basically ready to race. The parts installed make it still more than comfy enough to drive daily as well.
I also have a spare pre-facelift M20 manual conversion, 3.64 LSD with a delrin diff bush, rear sub frame with delrin bushes, set of rear trailing arms, M20 pre-facelift head and a face lift fibre glass iS lip, which can be negotiated with the sale of the car, or will be sold separately if the car is split.
Here are some pictures of what it has looked like in my ownership:
Posted Image
Posted Image
Posted Image
Posted Image
And here it is in its current for sale state:
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Any questions let me know, I am ideally looking to sell this as is and the price reflects that, if there is insufficent interest I will be parting it out.
Please PM me if you are interested.
Cheers, Nathan
Edited by Brams
Good luck with the sale Nath. What have you got on he go? Better be a bimmer!
Thanks Brett, picked up a nice E36 coupe at Turners, will put some pictures up in due course.
Wow good deal! Alot of decent works been done, GLWS
Good luck with the sale Nath! Seriously cool and fun car for the money and definitely goes as good as it sounds! Hope it stays in the BS family.
Thanks guys for the comments, car is now on hold subject to purchase arrangements, this will be updated if it falls through.
Cheers, Nathan
