Etwenty1 45 Report post Posted September 13, 2012 Had a look at an E39 528i tonight, been used as a bit of a farm hack and is rough but trying to decide if its worth cleaning up. I noted the following issues and am wondering how much is involved in fixing, whether they are common items or signs of larger problems; 1 Oil leak from cam cover running down onto exhaust manifold and leaking around front edge 2 Wet power steering hoses and fluid residue around neck of reservior 3 oil leak from oil pan/sump 4 front valence - ms type badly broken and guard liners broken - the whole piece will need replacing 5 Tail pipe badly rusted with holes 6 Oil thin and dirty ( yes i know) 7 engine sounded good starting up but after a drive had what i would call a gentle knock from the bottom end. This surprised me as it is supposed to be a low mileage repower. 8 front windscreen seal is badly perished and crumbling 9 ASC light is on and the button is dead. 10 AC is Not working Drives well except for a shimmy and has failed wof on a steering arm bush. DIY labour rates would apply. Quote Share this post Link to post Share on other sites
NZ BMW 368 Report post Posted September 13, 2012 Perhaps if you get it for free... Quote Share this post Link to post Share on other sites
Palazzo 522 Report post Posted September 13, 2012 As a reference, there was a tidy looking nz new 98 or 99 528i done 177kms at the car fair last week for 4500ono. Leather etc, looked well looked after. Quote Share this post Link to post Share on other sites
dereklau007 1 Report post Posted September 14, 2012 Perhaps if you get it for free... +1 Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted September 16, 2012 Sounds like a can of worms... For a start the ASC light is probably a crook ABS module. Needs scanning/diagnosing The engine knock/dirty oil is a worry. PS reservior seepage leak - is common & runs dowm hoses. Not necessarily a problem. AC - unknown, but could be costly. Oil leaks - self explanitory. Factor in replacement of suspension/thrust arm etc bushes/sway bar links. Windscreen -is just a trim - the screen is glued in Quote Share this post Link to post Share on other sites
