///MPROVD 135 Report post Posted September 29, 2012 hey guys my gearbox has started to make a rattle in neutral not sure what it could be, the noise goes away when i put the clutch in so im assuming its in the gearbox itself and will occasion not make a sound, it could also be rattling when im driving but i cant be sure, any ideas much appreciated Quote Share this post Link to post Share on other sites
BM WORLD 1297 Report post Posted September 29, 2012 quite comon , alwso will depend on how low your car idles at what does it idle at?? was teh a/c on , headlights on etc?? if it has a lighter flywheel that will also cause it to rattle a little. Quote Share this post Link to post Share on other sites
///MPROVD 135 Report post Posted September 29, 2012 quite comon , alwso will depend on how low your car idles at what does it idle at?? was teh a/c on , headlights on etc?? if it has a lighter flywheel that will also cause it to rattle a little. hey i have converted car to a manual it was the conversion kit i brought off you recently i had the flywheel,clutch etc done at auto clutch. car revs at auto idle and if you accelerate noise stops no headlights or a/c was just concerned if something was loose Quote Share this post Link to post Share on other sites
BM WORLD 1297 Report post Posted September 29, 2012 hey i have converted car to a manual it was the conversion kit i brought off you recently i had the flywheel,clutch etc done at auto clutch. car revs at auto idle and if you accelerate noise stops no headlights or a/c was just concerned if something was loosejust a lighter solid flywheel . my car does it and others that i have used a light flywheel in . not the dual mass type. its just the gears chattering on the lay shaft when no load is on them Quote Share this post Link to post Share on other sites
