samo455 7 Report post Posted October 3, 2012 hi guy and techs i have Googled the crap out of this and found no solution so time to ask the pros have an e36 325 was running great then one day it started dropping of cylinders one buy one got to the point any throttle gust starts pooping but still idles all good when its cold it runs great the temp cams up and it starts to miss the more i drive the worse it gets but the temp stay good i have changed all sensors maf 02 coil plugs any ideas Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 3, 2012 You would need to get it scanned first and go from there. Swapping things will only introduce more faults. Get someone up your way to diagnose and maybe fix it for you before it turns into something more major. Quote Share this post Link to post Share on other sites
BM WORLD 1297 Report post Posted October 3, 2012 possible water down the spark plug holes Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 3, 2012 possible water down the spark plug holes He said he did the plugs. Water should have been evident when he did it, unless the problem has occurred since they were changed Quote Share this post Link to post Share on other sites
samo455 7 Report post Posted October 4, 2012 yer no water down there just had them and scans clean no codes just evac that alway been there Quote Share this post Link to post Share on other sites
samo455 7 Report post Posted October 4, 2012 i meant code 1263 evap purge valve has always been there dont think i even have one the pluge is blanked of has any one herd of the ignitors in the dme dieing do ignitors do that when thay on there way out Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 4, 2012 (edited) What scanner was used and was the car driven and live data checked ?? With all this bad weather weve been having, your DME might have had a swim... quite common, depending on how it was parked, especially if the drains are blocked Edited October 4, 2012 by *Glenn* Quote Share this post Link to post Share on other sites
samo455 7 Report post Posted October 4, 2012 NA NO SCANNER JUST USE THE GOOD OLD 5 STOMP TRIK THERE ARE NO SIGNS OF WATER BUT THIS IS MY SECOND DME LAST ONE JUST LOST THE RIGHT SIDE OF THE DASH ENGINE STILL RAN TOUGH Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 4, 2012 NA NO SCANNER JUST USE THE GOOD OLD 5 STOMP TRIK A war dance won't help you fix your car.... it needs to be scanned by someone with a brain to asses the problem Quote Share this post Link to post Share on other sites
samo455 7 Report post Posted October 4, 2012 problem is living in the far north everyone with a brain is a robber just say bmw out loud and it cost u $150 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 4, 2012 problem is living in the far north everyone with a brain is a robber just say bmw out loud and it cost u $150 Thats cheap... in Auckland it's $450 and the robbers down here don't have brains Quote Share this post Link to post Share on other sites
