E30nut 1 Report post Posted October 29, 2012 I managed to find 15" steel wheels for my E30 but the bore size of those wheels are 60mm and the E30 bore size is 57.0mm by my understanding. Will it be safe to run the wheels with the 60mm bore size ?? or not ?? Cheers Jordache Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted October 29, 2012 You can get hub centric rings that will slot into the wheel bore and fit the wheel onto the hub. That way it fits snug and centres the wheel. Quote Share this post Link to post Share on other sites
E30nut 1 Report post Posted October 29, 2012 any idea where i could get some from and what size would they be ?? Thanks Quote Share this post Link to post Share on other sites
byza213 1 Report post Posted October 29, 2012 ive heard arrow wheels make customs rings .. give them a call to double check Quote Share this post Link to post Share on other sites
E30nut 1 Report post Posted October 29, 2012 ive heard arrow wheels make customs rings .. give them a call to double check Just emailed them, to see what the say.... fingers crossed. Any other suggestions??? Quote Share this post Link to post Share on other sites
byza213 1 Report post Posted October 29, 2012 Any other suggestions??? yup suggest giving them a call will be a tad quicker answer Quote Share this post Link to post Share on other sites
E30nut 1 Report post Posted October 29, 2012 true that, will do when i get the time. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted October 29, 2012 if 60mm is a standard size, you should be able to get them from mag and turbo or tonys tyres or beurepairs etc. or are they honda fitment 4x100? etc Quote Share this post Link to post Share on other sites
E30nut 1 Report post Posted October 29, 2012 if 60mm is a standard size, you should be able to get them from mag and turbo or tonys tyres or beurepairs etc. or are they honda fitment 4x100? etc thanks, they are from a nissan wingroad 4x100, but wasnt sure if it was safe to run them becaue the E30 hub bore is 57mm, but now will get the rings. Quote Share this post Link to post Share on other sites
DarinD 8 Report post Posted October 29, 2012 Precision wheels should be able to sort you out. Quote Share this post Link to post Share on other sites
E30nut 1 Report post Posted October 29, 2012 Precision wheels should be able to sort you out. will try them as well, would hyper or mag and tyre have any ?? Quote Share this post Link to post Share on other sites
_BRS_ 209 Report post Posted October 29, 2012 will try them as well, would hyper or mag and tyre have any ??pick up the phone and ring and ask! Quote Share this post Link to post Share on other sites
