alijanjan 3 Report post Posted November 25, 2012 AC blower on my new e46 isn't as powerful as my old e46, even when put on max fan speed still not much air coming out of the vents even on maximum still not enough to be useful, The fan does works as normal and makes all the right noises, its like the air is somehow escaping The final stage resistor is new and the fan seems to be running at max speed anyway ( and at constant speed) I tried all the stepping motors (5) and all seem to be working( all I did was checking to make sure they response to changes made on the climate control unit) unless they need to be calibrated some how My old e46 used to blow much more air ( while producing same noise) Any one had Sam problem? Everyone only talks about final stage resistor Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted November 25, 2012 dirty blocked micro filters Quote Share this post Link to post Share on other sites
alijanjan 3 Report post Posted November 25, 2012 dirty blocked micro filters Hi Brent have checked them, almost brand new Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted November 25, 2012 Hi Brent have checked them, almost brand new ok m check the FSR is pushed in properly and not leaking air out Quote Share this post Link to post Share on other sites
alijanjan 3 Report post Posted November 25, 2012 ok m check the FSR is pushed in properly and not leaking air out Just checked it, no leak Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 25, 2012 Has the flap linkage been refitted correctly on the servo motor next to the FSR and has the servo motor been plugged back in ?? Quote Share this post Link to post Share on other sites
alijanjan 3 Report post Posted November 30, 2012 Has the flap linkage been refitted correctly on the servo motor next to the FSR and has the servo motor been plugged back in ??Hi GlennJust double checked, all seems ok Quote Share this post Link to post Share on other sites
alijanjan 3 Report post Posted August 27, 2016 (edited) Hi Guys I know its been 4 years but just in case someone else have the same issue. I have found the problem and fixed the issue, it is so strong that it can now blow you away, have to make sure sit belts are on before starting the AC :-) after so many times of pulling the blower motor out thinking may be the evaporator is blocked/dirty or something similar i thought i replace the blower motor just in case. I started looking online for a new motor when I realized the cable on my motor comes out from the wrong direction compared to a DIY i was watching on youtube after checking and taking in out again, it turned out the motor was put it the wrong way meaning it would turn the wrong way and blow up instead of blowing down through the evaporator. took it out, turned it 180 degree and put back together and now it works great. very strange but someone must have put it in the wrong way at some stage. the strange part is that from the history i got when i bought the car, it seem to always been serviced by BMW until i bought it. also there was nothing in the service history of anything done on the AC system Maybebe this can help someone with the same issue cheers Edited August 27, 2016 by alijanjan 1 Quote Share this post Link to post Share on other sites
