vendt 1 Report post Posted November 29, 2012 Hi all looks like my emission control air pump has cr@ped itself ,is it possible to bypass this in anyway or do i need to replace it,any help would be great.thanks Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 29, 2012 The pumps normally crap out because the EGR valve is faulty. The diaphragm goes in the valve allowing moisture to get into the pump and damaging the bearings. You will need new or 2nd hand parts and I suggest you replace the EGR filter as well. What is the fault with the pump, just noisy or does it not work ? Quote Share this post Link to post Share on other sites
vendt 1 Report post Posted November 29, 2012 The pumps normally crap out because the EGR valve is faulty. The diaphragm goes in the valve allowing moisture to get into the pump and damaging the bearings. You will need new or 2nd hand parts and I suggest you replace the EGR filter as well. What is the fault with the pump, just noisy or does it not work ?just noisy and it makes a high pitched sound it feels like a bearing,whats a EGR ? i plan on doing a diy like most things on my car, wheres the best place for parts price wise,how important is it to do,can in leave it till after xmas? need to save money cheers Quote Share this post Link to post Share on other sites
HELLBM 1674 Report post Posted November 29, 2012 Can supply parts needed. Regards Ray Quote Share this post Link to post Share on other sites
