Chrismx5 0 Report post Posted December 2, 2012 Hey all, weird question.. I first picked up the beemer about 2 weeks ago, and the clutch had about 4 - 5 inches before it engaged, weird, but fine. Then today, it has about 5mm of travel, the clutch isn't slipping... What could it be? :/ Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted December 2, 2012 The clutch is hydraulic so has a master and slave cylinder and a fluid reservoir, check it has enough fluid and make sure the master (found behind the clutch pedal) and the slave, which is on the side of the gearbox are not leaking any fluid which would cause it to lose pressure.. If they aren't leaking then could be the seals inside the slave or the master. Quote Share this post Link to post Share on other sites
Chrismx5 0 Report post Posted December 2, 2012 The clutch is hydraulic so has a master and slave cylinder and a fluid reservoir, check it has enough fluid and make sure the master (found behind the clutch pedal) and the slave, which is on the side of the gearbox are not leaking any fluid which would cause it to lose pressure.. If they aren't leaking then could be the seals inside the slave or the master. Awesome! That was my initial thought, but wasn't sure if the e30 had a cable clutch or not Quote Share this post Link to post Share on other sites
Chrismx5 0 Report post Posted December 3, 2012 Annnd it worked =] nice and easy! Quote Share this post Link to post Share on other sites
Chrismx5 0 Report post Posted December 5, 2012 Okay I lied. It is leaking from under the car.... seems to be leaking around the gear box? Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted December 5, 2012 Slave cylinder will be leaking then, sits on the side of the gearbox (usually passenger side). Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 5, 2012 It would be wise to replace both the slave & master cylinders Quote Share this post Link to post Share on other sites
