pulse 9 Report post Posted December 3, 2012 Hi, I'm getting a knocking sound most of the time when I drive over a pothole or any kind of bump. It used to happen very rarely, but over time it now happens very regularly. The car feels fine to drive, just an annoying "knock" every now and then - sounds like it's coming from the front right. I suspect it's a bush, does that sound right? Could it be something else? Much appreciated. Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted December 3, 2012 Could just be a sway bar drop link - they're pretty common to knock, and are cheap/easy to replace. They tend to get worse and worse, until they are clicking over rough surfaces and small bumps too. Quote Share this post Link to post Share on other sites
pulse 9 Report post Posted December 3, 2012 Could just be a sway bar drop link - they're pretty common to knock, and are cheap/easy to replace. They tend to get worse and worse, until they are clicking over rough surfaces and small bumps too. Thanks! I'll check it tonight. Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted December 4, 2012 also the bolts the hold them on come loss some times Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted December 4, 2012 Could also be a stuffed shock. Had that before with spookily similar symptoms. Quote Share this post Link to post Share on other sites
