*Glenn* 856 Report post Posted January 4, 2013 I know this is a long shot... I'm after a TBA for a 2008 E92 M3 TBA = Throttle body actuator Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 4, 2013 I have a V10 one, probably different though? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 4, 2013 I have a V10 one, probably different though? Thanx Greg... I'll check ETK at work Monday morning.. they may be the same. There are two on the motor, but these are not handed L & R. I swapped them to confirm my diagnosis Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 5, 2013 Thanx Greg... I'll check ETK at work Monday morning.. they may be the same. There are two on the motor, but these are not handed L & R. I swapped them to confirm my diagnosisYes we did the same diagnos's as well, swapped side to side.The one I removed had slipped a tooth and shut down, I pulled it apart, realigned it and now works mint. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 5, 2013 This one won't achieve pre opp alignment without trying to start it a couple of times and goes into limp mode Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 5, 2013 Ah ok. Rooted. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 5, 2013 Ah ok. Rooted. Probably.. the only thing I haven't checked yet is the dissy cap though.. what do you think ? Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 5, 2013 Def worth a try. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted January 5, 2013 Probably.. the only thing I haven't checked yet is the dissy cap though.. what do you think ? Don't forget the rotor too Glenn Quote Share this post Link to post Share on other sites
