BMRBOI
E36 Parts-Turbo gear, Suspension, brakes, E30 and E46
E36 M50/M52 turbo top mount manifold, Turbo Specialties fuel injector controller and injector block, M3 fuel pump and intercooler. The injector controller and fuel pump was from a turbo M3 (the guys on here I believe). Doesn’t come with the oil cooler or oil lines (for extra). $500
SPC Camber kit for e36 has castor and camber adjustment (Hi-spec gear). One bolt thread is a little sloppy and has had strut tower bolts cut down. $150 sold
KYB short shocks done less than 500km. Comes with super low springs, had a bit of rear guard rub with 18x8.5 and minimal camber. Shocks cost me $200 alone. Want $300.
Ruff sub frame bushes and pins. $50
E36 325i exhaust/rps muffler, too loud for WOF without silencer. Can cut muffler off and mount euro tip etc to it. Box of beer? sold
7 igniton coils, unsure of conditions. Offers
18 button obc and cycle stork, cruise control stork and window wiper stork. All untested $100
E46 330i front rotors in good condition with pad wear sensor (believe they are genuine no lip, one has a chip)
E36 front 325i rotors and calipers with 328i rear rotors and calipers all in good condition. $200.
E36 325i rear brakes and rotors. $50
Goodridge braided lines its only a 4 line kit cost me $160 still have receipt for warranty. $50 Sold
Genuine E36/46 Front brake pads. Unused $80
E36 medium case diff. 3.15 ratio from a NZ BMW $100 Sold
E36 Flywheel, clutch/pressure plate and starter motor. Comes with two clutch plates. $80
E30 throughout bearing, pilot bearing and 325i oil filter. Unused $40
E36 springs, from a 325i sedan M-sport optioned. Offers
Am open to offers. Will swap for fog lights and mounting brackets and window switches.
Thanks Niroy
Edited by BMRBOI
Out of curiosity, how much is that injector controller worth?
New
Visit My Website
Second hand unsure. i just went with the round figure of $500 for the lot.
Starting to add things on Trademe.
Turbo stuff- $450 reserve turbo
Suspension- $200 reserve Suspension
Exhaust- $1 reserve RPS
Camber plates- $100 reserve SPC
Are the M-spec springs any lower / firmer than stock?
I believe this is true, hence the colour coding on the springs. If only I knew what these colours ment...
How much for the oil cooler?
Umm $180. Brand new, think its 13 or 15 row comes with lines and a sandwhich plate thingy.
