BlowMyWhistle
Heater controls?
Hi Y'all, I know I've asked this before, but I been doing some research on it and need a quick answer...
The 3 slides for the vents, footwell, cabin and screen...
Would I be correct in assuming the central slide (cabin) is fresh air only? Not heat?
The problem is I have unremitting HOT coming from the top and bottom vents only, unless I close them.
The central slide is fine, but the only one I can have open without a blast of hot air.
My sources tell Me that it could be a) both the motor controls behind the stereo, or B) the mono valve.
I can get a new valve easily enough, but they not free, about $130 from USA, more on Pelicans...
Had this once in an e34 in NZ, was just a fuse!
I think it unlikely for both motors to similtaneously fail?
It'd be nice to be able to have ful air con, specially days when it's 40*C
The ear con will only blow cold thru the central vent, top open = hot, bottom open = hot.
Regardless of the temperature controls.
So why only top and bottom, not centre slide??
most likely the heater valve unit in the engine bay is stuffed jammed up , perished seals etc.
so the hot water just keeps on flowing through the heater cores.
comon issue with these old e34 and e32 etc even in the e36 e39 e38 models
Yeah, thanks for that, guess I'm putting my hand in my pocket...
But what about the middle slide, how come that is not affected? Is that fresh air only, not thru the heater?
correct fresh air only so you dont fall asleep , but some have a middle dial between the front vents to allow some wram air in the face
Cheers, new mono valve then.
I don't see it as an old car. it's 18 years old, but still like a new car!
Thought about trading to e39, but whats the difference??
Running it into the ground 300k's an counting!
e34 best car that bmw built .
before the accountants stepped in
Last quality car they made no doubt
as shown when the interior of a 20 year old car with 250000 ks is in better condition than a 6 yr old car with 80 000 ks
Got a new valve for it! Xfingers! Killer on these 42* days!
