Carl
Shocks
So who is running what shocks? Bilstein, Koni, KYB...
I'm running Koni adjustable sports (yellows) which are great but i'm only every adjusting the fronts between the track and daily use. How do I adjust the rear shocks? Glenn? Damian? Sam? Someone help me on this one please.
Yes, I thought that was the case, but do you need to fully remove the shock or can you just detach the bottom and compress it up and then turn it?
You need to remove the shocks.
At the top of the steel shaft cover pain-in-the-arse thing there are small holes.
Fully extend the shock, shove something into the hole (keep it clean guys!!) to push down the bump-stop and remove it through the gap, then compress and twist.
Those are the instructions I got From Stocks.
I've been PM'd a picture from the manual, very interesting, but at any rate the shocks need to come out.
So, back to the original question, what shocks are you running?
Koni Coil overs front w/350# springs
AVO Coil overs rear haven't decided on sprngs yet, prolly 300-350#
Adjustable Koni (yellow) Lowered Kings springs in front (down 15 mm), standard in rear springs. E36 M3 lower control arm bushes in front to get more castor for 17 inch wheels. M3 strut brace
Urethane rear control arm bushes, Urethane front and rear sway bar bushes
What do you think of it??
Any thing you would change?
just out of interest....the e30 motorsport rear sway bar is thicker than the stock one. the fronts seem about the same. the stiffer rear makes turning in better, and seems to have cured my understeer problem a bit...really need to do at track but yeah, i didnt change for ages as i thought they were same, before actually comparing
next suspension mod.....try andys 40mm drop jamexes...maybe some urethane or M3 CAB's.....pretty happy other wise is a mint road setup, just needs more at the track..but cant win em all
maybe dunlop formula R's..badass
