328bema
700hp+ "FrankensteiN M50B28 Turbo project
Does putting the engine on an angle have any negative effects? Especially with oil flow? Looks mean though, add me to to the list of people keen to see it running
Cheers bro and hard the man crunchy pretty much answered your question. If you dont take to much slant out of it the less things you need to modify. Stand the motor up anymore than i have here you will need to modify gear shifter linkages, sump, and possibly the bonnet :)
small amount doesnt hurt
ive done mine alot more than you see here and redesigned the sump, the windage and oil pickup in the M50 is pretty rubbish the pickup sits 45mm from the bottom thats where the mess finishes and the tube starts ideal is 10mm off the bottom so i cut mine off and re fab the whole sump etc
Hey crunchy what cams are you running on your motor? :)
If you are wondering where to get your oil feed from here are some good locations, you may need to tap threads but if you find the right fitting there will be no need. I found on "some" not all m50/52 oil filter housings, bmw have placed two allen key bolts you can undo and use for your turbo oil feed. I have used one for temp and one for feed. Or you can simply tap the banjo bolt for vanos oil feed. Or make/buy a distrubution block that screws into the oil pressure switch loction. :)
Any updates? Has been a while. I'm just abit the head down this road but not as extreme.
Hey brother sorry about the late reply have been abit slack on the updates, I will get something up during the week. Do it bro! You going to post your build up? :)
Well friends it has been a while since I have posted anything up on here. Here are some pictures of the rear evo sub frame and ruff bushings :) looks nice compared to how it was before, all rusty and shyt haha. Just posting up a few pictures from a while ago cause my instagram account was closed down. :)
post-3986-0-25725900-1411295322_thumb.pn
post-3986-0-02981900-1411295364_thumb.pn
post-3986-0-65980900-1411295416_thumb.pn
post-3986-0-41850300-1411295450_thumb.pn
post-3986-0-72247600-1411295491_thumb.pn
post-3986-0-69588800-1411295538_thumb.jp
Nice!
I decided against going the turbo route, can't maintain an m3 and do a turbo build haha!
Nice!
Haha well that is very understandable, I should have just brought a m3 instead haha :)
It makes it hard when you dont have all the right tools and shyt, went and got some thick ass steam pipe to build the turbo manifold, all I had was a grinder and hammer. Took me ages to grind and cut but came out alright :)
post-3986-0-42314000-1411347653_thumb.jp
post-3986-0-49793500-1411347720_thumb.jp
post-3986-0-31684100-1411347757_thumb.jp
post-3986-0-05642000-1411347792_thumb.jp
post-3986-0-47536100-1411347839_thumb.jp
post-3986-0-19348700-1411347913_thumb.jp
Awesome work on the manifold. :) I spent days on mine then decided to scrap it and sent the car to sinco to have it built.
Thanks bro hard I have thought about doing that too, its a mission building the manifold but also a good challenge :)
For my stock motor im using a cut-ring head gasket, the rings have groves in them which cut into the cylinder head allowing it to seal like a gangster bitch. MLS are good but dont want any issues so this is the way to go. On the good motor im running pyramid rings which are similar but hold alot more boost. :)
head gaskets aren't the only issue to why they blow them im running a stock gasket on my m50 its never given issue, my m42 runs over 20psi on stock gasket and done so for the last 30k
just my opinion
just my opinion
Haha im dropping the compression a little with this hg, I dont have to worry about blowing it with my numbers thats for sure haha
if your using the ARP 2000 stock replacement studs i wouldnt, use the Custom age 625 or as i do go up in stud size
Edited by crunchy
Hardcore bro I went up in size for my good motor but for this one I ended up staying with stock size studs, they cost alot bloody hell haha :)
none of it is cheap i guess im lucky i can make pretty much all of it
Time to build another manifold, wasn't to happy with the last, takes a long time for me to make this shyt but I put alot of effort into these things so it should come out nice :) check out my flange haha 12mm thick mild steel :)
post-3986-0-93302200-1411780333_thumb.jp
Edited by King Arthur
Hi all, well since my brother Arthur passed away in April of this year, he asked me to put his ride back to it's original state. I have yet to decide 100% on whether or not to continue with the Turbo build, in all honesty i am far from the imagination, and skill that my brother had in order to continue with everything he'd done before late last year. This year has been riddled with family and friends passing away left right and center, where to from here?? So yeah, denfinitely got me considering options now..
However, i will not rule out the dream, it would be amazing to complete this Project, it was a shared passion and dream as brothers. Currently nothing has changed in regards to the build, i have still kept his account running, no real need to shut it down just yet....?
post-3986-0-13551500-1441810953_thumb.jp
