M5V8
E39 occasional Stall
Hey team....I'm in need of some bimmersport advice.
02 E39 M5
So the car will stall on low rpm. first happened about a year ago but has happened two or three times in the last few months (although I am driving her more regularly now).
It only happens when she's been running for sometime. Only when its basically idling. When I slow from highway speed put it in neutral and crawl upto a intersection. it just dies. Hit the key and it fires right up.
Never happens if I run down through the rev range in every gear.
Wife says it's objecting to being driven like a grandma.
I ignored the first few times it did it but now it's starting to annoy.
Any ideas where to start?
Start with a scan and see what turns up first. The fault may be recorded without throwing the check engine light
Also have a look at the live data and check the Idle Control input value. It should match the MAF intake values.
The cause could be anything, but my bet is a intake vaccum issue. As Glenn says a scan might just bring up some tell tail signs in the shadow memory.
If the errors are sporadic, you should have a count how many times they happen. If theyre constant then it may be a lot more obvious.
thanks for the feedback....
I guess I'll have to have a trip to mr Jeff grey unless there's someone else in wtgn that can scan?
I'm thinking this might be hard to track down... it's really only happened maybe 5-6 times in total?
Just the twice in the last month annoyed me. Quite embarrassing.
