vanossa 0 Report post Posted March 15, 2013 Hi. 93' E36 325i Coupe (euro build/import), just recently failed the WOF for the dash indicator display being faulty. This was missed on previous WOFs and I have noticed it being faulty for about a year or so...? The external front and back indicator lights all work, but for the dash display on the left? Is this an 'easy fix' ? Anybody else had this before?...Thanks in advance. Quote Share this post Link to post Share on other sites
BM WORLD 1270 Report post Posted March 15, 2013 do you mean they cant read the odometer??? replace the back light bulb fro a new one Quote Share this post Link to post Share on other sites
turbolizard 38 Report post Posted March 15, 2013 I think the post refers to the turn signal indicator lamp in the dash - the one that blinks in synch with the turn signals which are working outside the car. If so it is most likely just a bulb and you could possibly just swap one in from an unused location on the back of the cluster (you might have unused warning lights for options you car does not have). I found some of the right bulbs for my e34 instrument cluster at the local Ford Dealer. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2122 Report post Posted March 16, 2013 If you mean the part where the amount of kms the car has done is displayed, usually the ribbon cable. Got it done on my E34 a few years back, was a reccomendation from someone on here so if you search you should find it. I think they do a "no repair, no fee" gaurentee on it Need to get mine done too soon actually. But you shouldnt fail a WOF on that though unless your car is diesel Quote Share this post Link to post Share on other sites
vanossa 0 Report post Posted March 17, 2013 I think the post refers to the turn signal indicator lamp in the dash - the one that blinks in synch with the turn signals which are working outside the car. Yeah, sorry for the confusion. I do refer to the Turn Signal Indicator lamp on the dash. Quote Share this post Link to post Share on other sites
BM WORLD 1270 Report post Posted March 17, 2013 I think the post refers to the turn signal indicator lamp in the dash - the one that blinks in synch with the turn signals which are working outside the car. Yeah, sorry for the confusion. I do refer to the Turn Signal Indicator lamp on the dash. just replace the bulb in the dash easy enough job Quote Share this post Link to post Share on other sites
vanossa 0 Report post Posted March 17, 2013 (edited) I think the post refers to the turn signal indicator lamp in the dash - the one that blinks in synch with the turn signals which are working outside the car. Yeah, sorry for the confusion. I do refer to the Turn Signal Indicator lamp on the dash. just replace the bulb in the dash easy enough job Cheers Brent and everyone. Edited March 17, 2013 by vanossa Quote Share this post Link to post Share on other sites
my_e36 43 Report post Posted March 17, 2013 When you remove the cluster from the dash, there will be no need to remove the steering wheel. Quote Share this post Link to post Share on other sites
