albert72 0 Report post Posted March 16, 2013 (edited) Manage to stripped the bolt/shaft where steering wheel bolts on The nut that holds the steering wheel (which is also stripped) is M14x1.5. I'm considering re-threading the bolt/shaft with a tap and die set which I know very little of. Should I use a M14x1.5 die on the shaft/bolt??? Edited July 3, 2013 by Tom325 Quote Share this post Link to post Share on other sites
albert72 0 Report post Posted March 17, 2013 bump Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted March 17, 2013 is this for the e30 , just replace the shaft etc. from another parts car like this one http://www.bimmersport.co.nz/forums/index....showtopic=41433 Quote Share this post Link to post Share on other sites
RAH 6 Report post Posted March 17, 2013 Manage to stripped the bolt/shaft where steering wheel bolts on The nut that holds the steering wheel (which is also stripped) is M14x1.5. I'm considering re-threading the bolt/shaft with a tap and die set which I know very little of. Should I use a M14x1.5 die on the shaft/bolt??? If the thread is truly stripped then you will need to replace the shaft. Using a Die nut will only retrace the existing thread or whats left of it. Quote Share this post Link to post Share on other sites
danutt 4 Report post Posted March 21, 2013 If the thread is truly stripped then you will need to replace the shaft. Using a Die nut will only retrace the existing thread or whats left of it. dont know tooo much on this but im sure you can have it re threaded wit a re threading tool and use a small nut and different washer and bob your uncle haha http://www.google.co.nz/imgres?q=rethreadi...106&bih=626 copy past that or there are other tool kits call around someone may be able to come out to u Quote Share this post Link to post Share on other sites
albert72 0 Report post Posted March 22, 2013 M14X1.5 tap and die did the trick !!! Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 22, 2013 M14X1.5 tap and die did the trick !!! I very much doubt that the recovered thread from using the tap and die will be strong enough to be safe. Did you tighten it to 80 Nm ?? Quote Share this post Link to post Share on other sites
danutt 4 Report post Posted March 22, 2013 one more thing bro-----HOW ON EARTH DID YOU MUNT IT LIKE THAT IN THE FIRST PLACE??HAHAHA Quote Share this post Link to post Share on other sites
albert72 0 Report post Posted March 22, 2013 I very much doubt that the recovered thread from using the tap and die will be strong enough to be safe. Did you tighten it to 80 Nm ?? Yes I did Quote Share this post Link to post Share on other sites
albert72 0 Report post Posted March 22, 2013 one more thing bro-----HOW ON EARTH DID YOU MUNT IT LIKE THAT IN THE FIRST PLACE??HAHAHA Was too lazy to use a socket wrench to bolt back the steering wheel. Use impact gun instead, didn't realized that the nut was misaligned when I put it on!!! Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 22, 2013 Can I check it for free to maybe save your life or someone elses ?? Quote Share this post Link to post Share on other sites
albert72 0 Report post Posted March 22, 2013 (edited) Can I check it for free to maybe save your life or someone elses ?? Thanks for the offer, but no need. Already had it checked today by my mechanic👠Edited March 22, 2013 by Tom325 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 22, 2013 Thanks for the offer, but no need. Already had it checked today by my mechanic👠Good.. I really hope you did... I have had a steering wheel come off while driving...not a very nice experience. You don't know how much leverage you put on a wheel while driving untill it comes loose or breaks free. Quote Share this post Link to post Share on other sites
albert72 0 Report post Posted March 22, 2013 Good.. I really hope you did... I have had a steering wheel come off while driving...not a very nice experience. You don't know how much leverage you put on a wheel while driving untill it comes loose or breaks free. I know what you mean. I forgot to mention that also I applied some loctite threadlocker. Thanks again Quote Share this post Link to post Share on other sites
