xxenragedxx 0 Report post Posted March 29, 2013 Hey guys. Bit of a noob when it comes to this. Putting it simply when I'm cruising at 100 my car is sitting on 4000 revs. Everything is standard aside from a manual conversion so on gathering its the differential? Any ideas on what diff to get and what's the cheapest option? The donor car was a 323i and mine is a 320i Quote Share this post Link to post Share on other sites
thorburn 122 Report post Posted March 29, 2013 Your output in 5th gear will now be 1:1. I'd go for a 2.93, 3.15 or 3.23. The lower the number the lower your revs will be at 100k's Quote Share this post Link to post Share on other sites
danutt 4 Report post Posted March 29, 2013 Your output in 5th gear will now be 1:1. I'd go for a 2.93, 3.15 or 3.23. The lower the number the lower your revs will be at 100k's id go with a 3.64 on the e30 i have the lsd and sits just below 3k when at 100-or around there-sounds like you have a 4.27 or there abouts have had that before gives good acceleration but consumption goes up -did a manual coversion on a 318i with 4.45 small case open diff gave very close ratios...have a look at the tag and go from there Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted March 29, 2013 E36 ratios arnt the same as e30s. E36 manual box 1 to 1 5th gear. E30 box 0.8 to 1 5th gear. 3.6 is good on e30 not on e36 Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted March 30, 2013 select your getbox type probably getrag 250 , then selct tyre size etc. http://members.dodo.com.au/~wawawa/revs.htm Quote Share this post Link to post Share on other sites
