IPLEZR 0 Report post Posted April 7, 2013 Iv got a problem with my 1989 E30 indicators. I thought it may have been the flasher relay but that was a fail. Whats happening is when i signal left it works normal and fine, but when i signal right, the 3pin flasher relay on steering colum humms and no indicator light goes. The hazard lights dont work aswel. Iv tried replacing the relay but still does the same thing, iv tried replacing the hazard light switch but that does nothing either. has anyone had this problem or know the answer to my problem? Cheers Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted April 7, 2013 all the bits if you need anything Scott. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2136 Report post Posted April 7, 2013 usually a dodgy hazard switch. but you say you have replaced hmmm. could be two dodgy hazard switches? stalk? indicator system not too complicated on the E30 Quote Share this post Link to post Share on other sites
bmw335i 16 Report post Posted April 7, 2013 Try replacing the indicator stalk. I had no indicators on my e30 not long ago. Ended up replacing hazard switch and relay on colum with no results. Turned out to be the indicator stalk. cheers, Troy. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted April 8, 2013 A short in the R/H circuit likely. Quote Share this post Link to post Share on other sites
IPLEZR 0 Report post Posted April 8, 2013 Hey thanks for the feedback everyone. Will contact you during the week dave thanks Quote Share this post Link to post Share on other sites
