aw-krazy 45 Report post Posted April 15, 2013 Looking for an m30b35 anyone selling one cheap? Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted April 15, 2013 Looking for an m30b35 anyone selling one cheap?whats it going into , which version do you want ?? i have a early high power 10;1 compression ratio type or are you wanting one of the lower power lower compression later ones?? what do you call cheap?? have it listed here . http://www.trademe.co.nz/motors/car-parts-...n-580937354.htm but call me if you want to talk turkey 021433600 [email protected] also have a lower block only , and can probably find a head if you want to build one up etc. http://www.trademe.co.nz/motors/car-parts-...n-582081842.htm Quote Share this post Link to post Share on other sites
aw-krazy 45 Report post Posted April 15, 2013 whats it going into , which version do you want ?? i have a early high power 10;1 compression ratio type or are you wanting one of the lower power lower compression later ones?? what do you call cheap?? have it listed here . http://www.trademe.co.nz/motors/car-parts-...n-580937354.htm but call me if you want to talk turkey 021433600 [email protected] also have a lower block only , and can probably find a head if you want to build one up etc. http://www.trademe.co.nz/motors/car-parts-...n-582081842.htm Im looking to put one into an e34 chassis, so probably the early 535i e34 m30 engine as i assume that would be more straight forward was hoping to get something around 6- 700$ just after the engine without loom Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted April 15, 2013 Im looking to put one into an e34 chassis, so probably the early 535i e34 m30 engine as i assume that would be more straight forward was hoping to get something around 6- 700$ just after the engine without loomokare you thinking of putting it into your 520i?? i think you will want the e34 535i engine or e32 735i engine you will need the matching trans , driveshaft , exhaust , engine loom , ecu afm , rad and plenty of other parts etc etc. early engine 1982 to 1987 can be fitted in place of a later engine 1988-1992 or is it going into a 535i with a stuffed engine?? Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted April 16, 2013 Bugger, I sold a complete engine with ecu in good order for $500 late last year. Was probably less than what it should have been worth however. Quote Share this post Link to post Share on other sites
aw-krazy 45 Report post Posted April 16, 2013 Im putting one into an already 535i e34 so yeah just looking for a good cond one that wont give me problems , Out of curiosity how would a m30b35 fit into a 520i M50 1995 model Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted April 16, 2013 Im putting one into an already 535i e34 so yeah just looking for a good cond one that wont give me problems , Out of curiosity how would a m30b35 fit into a 520i M50 1995 model ok you can have the one from the 635csi for $700 , come help pull it out. not worth putting a 3.5 into the 520i , better to fit a e36 328i or e39 528i single vanos engine into the 520i or a 325i 525i type etc will make it go quite well and no need to change the gearbox or wring etc etc . bolts straight in. Quote Share this post Link to post Share on other sites
aw-krazy 45 Report post Posted April 16, 2013 ok you can have the one from the 635csi for $700 , come help pull it out. not worth putting a 3.5 into the 520i , better to fit a e36 328i or e39 528i single vanos engine into the 520i or a 325i 525i type etc will make it go quite well and no need to change the gearbox or wring etc etc . bolts straight in. An M52 would bolt straight into my M50 without having to change anything? ECU or EWS problems at all? Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted April 16, 2013 You would need an early m50b25 ecu with no ews. and to swap all the sensors and electrical parts over. no idea which m50b20 electrics will work with m52b28 swap. also need the sump from your m50 onto the m52. Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted April 17, 2013 An M52 would bolt straight into my M50 without having to change anything? ECU or EWS problems at all? just use all of your electrics , change the afm to the bigger 328i type . remap the ecu . or use the ecu ews and chip from the 328i etc . use teh m50 sump , exhaust manifold and a 325i m50 intake etc . lots of different ways of doing it depending on what parts you use or get etc. or just run it on the 520i ecu , afm manifolds etc , will just be strangled a little for topend power Quote Share this post Link to post Share on other sites
