Gus 5 Report post Posted August 25, 2005 just out of interest for anyone curious, the motorsport rear sway bar is thicker than the stock 325i rear. the fronts seem about the same. just putting it up cos i thought they were the same till i actualyl compared them makes the turn in better, and hopefully my little understeer can turn into oversteer. feels really good. make sure all ya sway bar linkages and shizzle are in good nick too, it all helps Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted August 27, 2005 stock is 13mm ® what are yours? Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted August 27, 2005 14.5?? dont have calipers...you can notice the thickness as it is the same where the sway bar bush slides on...on the 325i ones its that thickness the whole way, on the motorsports it gets thicker Quote Share this post Link to post Share on other sites
topless 7 Report post Posted September 3, 2005 Just measured (with vernier) the ones I have. 325 cab is 12.3, M325 is 14.6. Quote Share this post Link to post Share on other sites
