cainchapman 0 Report post Posted August 29, 2005 Read paragraph 2 in the centre column. Quote Share this post Link to post Share on other sites
bmwsparkle 3 Report post Posted August 29, 2005 primo, may hav to try them next time Quote Share this post Link to post Share on other sites
TronSpec 0 Report post Posted September 27, 2005 Did you guys know that connected down behind the brake pedal is aye big rod that goes from the brake pedal behind the firewall to the master cylinder is adjustable. Need 2 17mm ring spaners (note. this is f**ken done up tight!) Adjust accordingly. I had re honed and kitted my master cylinder, new rotors all round, metal king pads, new dot 4 fluid but pedal feel was still sh*t. Adjusted this rod prestow. Note. Don't over adjust as this will push the master cylinder rod right in and brakes will be stuck on. Quote Share this post Link to post Share on other sites
