deeveus 81 Report post Posted May 13, 2013 I've had a quick poke around, but cannot see how to get in to replace this bulb, is there something I'm missing? 2005 E90 Cheers. Quote Share this post Link to post Share on other sites
Escay 0 Report post Posted May 13, 2013 which light? Do you mean the AE bulb? On the E90 its quite a mission, to replace it you have to go in through the wheel well Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 13, 2013 Turn the wheel on full lock. There is an access flap in the guard liner Quote Share this post Link to post Share on other sites
deeveus 81 Report post Posted May 13, 2013 (edited) Thanks Glenn, I've had a look about on Forums, and some people are taking wheels off, for a fkn parklight bulb??? Unreal! Edited May 13, 2013 by The Diesel Guy Quote Share this post Link to post Share on other sites
matt45 1 Report post Posted May 13, 2013 Thanks Glenn, I've had a look about on Forums, and some people are taking wheels off, for a fkn parklight bulb??? Unreal! O_o i've done mine at full lock ... shouldn't be that hard. Quote Share this post Link to post Share on other sites
deeveus 81 Report post Posted May 22, 2013 The question I have, how do you get to remove the cover and unscrew the bulb without taking off the inner guard? You can access it via that inspection panel? I dunno why they've made it so difficult to change bulbs, I guess it's to get people into the dealership! Quote Share this post Link to post Share on other sites
Escay 0 Report post Posted May 22, 2013 You can't access it without taking off the wheel well liner. It's a stupid design flaw, on e92s its easy a pie. Quote Share this post Link to post Share on other sites
deeveus 81 Report post Posted May 22, 2013 You can't access it without taking off the wheel well liner. It's a stupid design flaw, on e92s its easy a pie. Yeah just as I thought really, which means jacking up and taking the wheel off and making easier access to nuts e.t.c Quote Share this post Link to post Share on other sites
Escay 0 Report post Posted May 22, 2013 if you have the tools, then taking the wheel off would make life a lot easier. But it is doable just by turning the wheels full lock, it will give you enough space to work. Quote Share this post Link to post Share on other sites
