Feist92 0 Report post Posted May 14, 2013 Hey guys Just done a manual conversion on my 98 e36, btw thanks Brent for all the bits. It has been going perfect for about 300kms but just the other other day ive started to get gear chatter. It only happens with the clutch out in neutral and gets worse as it warms up, I did put in a single mass m20 flywheel that I lightened a little but only very conservatively. I have a feeling the oil I put in the gearbox is too thin which leads me to my question. What gearbox oil are you guys running and where do you get it? I ended up putting in nulon synthetic atf but would appreciate any suggestions Cheers Jonathan Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 14, 2013 I use Elf 75w80 full synthetic synthese gearbox oil and still get a little rattle after spirited driving Quote Share this post Link to post Share on other sites
Feist92 0 Report post Posted May 14, 2013 I use Elf 75w80 full synthetic synthese gearbox oil and still get a little rattle after spirited driving As far as I can tell that seems like a very good alternative. Did it at least improve the gear rattle? Also where have you been getting it from? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 14, 2013 We have it in stock Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted May 14, 2013 We have it in stock How much, Glenn? Quote Share this post Link to post Share on other sites
Feist92 0 Report post Posted May 15, 2013 How much, Glenn?I'll second that Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 15, 2013 $31.84 + Gst per litre Quote Share this post Link to post Share on other sites
///MPROVD 131 Report post Posted May 15, 2013 i had the same thing replaced the oil stopped rattle for all 10km so i asked around chatter is normal theres nothing to worry about Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted May 15, 2013 $31.84 + Gst per litre Excellent. Will be in touch Quote Share this post Link to post Share on other sites
Feist92 0 Report post Posted May 16, 2013 i had the same thing replaced the oil stopped rattle for all 10km so i asked around chatter is normal theres nothing to worry aboutWhat did you replace it with? Quote Share this post Link to post Share on other sites
