Eagle 1776 Report post Posted June 16, 2013 (edited) I just noticed today that Turner Motorsport are now selling the E34 25mm front sway bar, this along with the 20mm Nurburgring rear is a great upgrade. Im currently using it and it gives a far more neutral car with slight over steer bias instead of the standard under steering mess For both bars it ends up being a little over $600 landed which i think would be money well spent if you own an E34 http://www.turnermotorsport.com/p-20543-bm...-535i-540i.aspx http://www.turnermotorsport.com/p-16594-bm...5i-540i-m5.aspx Edited June 16, 2013 by Eagle Quote Share this post Link to post Share on other sites
MattA 165 Report post Posted October 12, 2013 This setup may be even better having the option of adjustment. http://www.turnermotorsport.com/p-1303-racing-dynamics-sway-bar-set-e34-525i-530i-535i-540i-m5.aspx Just shy of NZD800 plus Customs and GST on landing, say $1k all up to your door. cheers Matt Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted October 13, 2013 im running coil overs that are quite hard, would it be a good idea to get these or does improvement likely to be less now? I'm running the factory sways. Quote Share this post Link to post Share on other sites
Eagle 1776 Report post Posted October 13, 2013 This setup may be even better having the option of adjustment. http://www.turnermotorsport.com/p-1303-racing-dynamics-sway-bar-set-e34-525i-530i-535i-540i-m5.aspx Just shy of NZD800 plus Customs and GST on landing, say $1k all up to your door. cheers Matt From what ive remember those RD bars had a bit of an understeer bias on your average street car. I think the 25\20mm work well for the usual street lowering springs+shocks. Andy:What sort of springs rates are you running on those XYZ's? An adjustable set would probably good if you wanted tweak handling characticstics Quote Share this post Link to post Share on other sites
