BM WORLD 1296 Report post Posted June 30, 2013 (edited) drop in a 325i 525i 528 328i vonos engine , use all your electrics , just get your ecu remaped if you want it percfect. maybe change the throttle body intake pipe and afm to the bigger 328i 528i etc . Edited June 30, 2013 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
matrox02 0 Report post Posted June 30, 2013 yeah, i have around 3k to do a engine replacement, and want it done via mechanic, i dunno how far that will take me tbh, and what sort of options that will limit me to Quote Share this post Link to post Share on other sites
matrox02 0 Report post Posted July 24, 2013 I Supposedly get the car back tomorrow.. I am kinda anxious on what it'll actually be like running properly and all :S Quote Share this post Link to post Share on other sites
Rgvkiwi 10 Report post Posted July 31, 2013 I Supposedly get the car back tomorrow.. I am kinda anxious on what it'll actually be like running properly and all :S and.....? Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted August 1, 2013 Just reread this thread man we are a confusing bunch! sounds like you have already made a plan. Cheapest solution is to find an M50B20 ex E34 and drop that in and your away. should be less than $3k including engine even at a specialist Quote Share this post Link to post Share on other sites
matrox02 0 Report post Posted August 2, 2013 (edited) Got it back with the m50b25 engine installed, It runs and drives well( loads quicker than i expected ), except because the Siemens ecu doesnt like the differant bore and stroke it wont idle well( waaay advanced timing ), misses and backfires through the intake, So im waiting on Gavin at Hi-Velocity to remap it when he is ready, would be much easier to go manual and convert to bosch but.. I want to keep it auto Edited August 2, 2013 by matrox02 Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted August 2, 2013 Should go better than a normal 525i when done then ! Quote Share this post Link to post Share on other sites
matrox02 0 Report post Posted August 3, 2013 Should go better than a normal 525i when done then !I can only hope so, I havnt been driving it so that I dont cause problems with valves burning and such, its getting annoying borrowing cars and using my motor cycle to get to work, as I work night shift and its still cold :-( Quote Share this post Link to post Share on other sites
matrox02 0 Report post Posted August 8, 2013 Fixed it! I when going to replace the intake manifold gaskets i found that.. A the new ones fitted perfectly around the ports on the head, and B, the intake gaskets where too big for the old manifold, so... For ANYONES referance in future, the m50b25 will replace the m50b20 100% working properly IF, you use a m50b25 intake manifold, if you use the old, it will leak like MAAAAD, so does anyone wunna buy a m50b20 intake manifold?? Quote Share this post Link to post Share on other sites
