aw-krazy 45 Report post Posted July 12, 2013 Im having problems with me 328i e36, . Whenever I try using electric windows and sunroof nothing happens untill I open the door then everything works again Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted July 12, 2013 Was the key in it and turned on? Mine do that but only without the key. Quote Share this post Link to post Share on other sites
aw-krazy 45 Report post Posted July 12, 2013 No ill get it when im driving :S Quote Share this post Link to post Share on other sites
BM WORLD 1297 Report post Posted July 12, 2013 one of the 5amp fuses blown , faulty comfort realy (behind glovebox blue colour) also make sure you all your door switches are working properly , drivers door one is quite often worn down etc Quote Share this post Link to post Share on other sites
aw-krazy 45 Report post Posted July 13, 2013 one of the 5amp fuses blown , faulty comfort realy (behind glovebox blue colour) also make sure you all your door switches are working properly , drivers door one is quite often worn down etc Cheers, thanks for the help will have a look tomorrow morning. Cant be a smoker and have all windows up... haha Quote Share this post Link to post Share on other sites
blonky 2 Report post Posted July 14, 2013 Had the same problem; was a 5A fuse under the hood Quote Share this post Link to post Share on other sites
aw-krazy 45 Report post Posted July 19, 2013 Had the same problem; was a 5A fuse under the hood You wouldnt happen to know which fuse number? Still trying to find it Quote Share this post Link to post Share on other sites
