Kaz
Basketweaves wont fit on an e30?
Hi there,
So I was trying to switch my old basketweaves onto my new e30 but for some reason the center bore was too small and wouldn't fit on the rear wheel hub? Front seemed to fit alright.
They fit fine on my old SA 1990 BMW 325, and currently on my 1987 BMW 318i, but they just wouldn't fit on my UK 1989 BMW tech 2 325. As far as I know everything is all standard on it.
Any idea why this might be?
Rust or Corrosion on either surface? It doesn't take much.
Nope there wasn't any rust or corrosion, I even tried scrubbing it down if that was the case. Seemed very weird to me, as it was sticking out a good 5-10mm out from the hub.
check there are not some hubcentic rings stuck on the hub or wheel , but otherwise rust etc
Edited by Brent HARTGE535i
Hmm I didn't notice any. I'll take them off again this weekend to have a better look.
