raewyn22 149 Report post Posted July 27, 2013 Hey guys, Any particular types of clips or screws to be used when mounting the fog lights for the e30 on the factory mounting points? Car had blanks on it held on by rubber clips. All suggestions appreciated Thanks Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted July 27, 2013 (edited) Hey guys, Any particular types of clips or screws to be used when mounting the fog lights for the e30 on the factory mounting points? Car had blanks on it held on by rubber clips. All suggestions appreciated Thanks no, uses the same clips and screws the blanks uses, just unscrew, remove blanks, and then put new brackets in etc edit: some E30s are prewired from the factory, if not, the fogs have thier own loom that runs along the front bumper behind it, and up the left fender, and clips on somewhere, there might be a plug empty there on the wing, or it might have to go to the junction box behind glovebox, i forget now. but they are definately on thier own loom Edited July 27, 2013 by _Ethrty-Andy_ Quote Share this post Link to post Share on other sites
raewyn22 149 Report post Posted July 27, 2013 no, uses the same clips and screws the blanks uses, just unscrew, remove blanks, and then put new brackets in etc Thanks Andy, but the clips I have off my car are plastic and they don't fit the brackets I have purchased. No screws either. Thinking of just buying some nuts and bolts that fit nicely. Can't wait to get it all set up though! Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted July 27, 2013 your talking about a facelift right? I have no idea what the setup for a prefacelift is. hmm im sure that there should be plastic bungs for want of better word that is pushed in the valance regardless of if fogs or blanks. i dont have an E30 in the drive to jog my memory sorry! Quote Share this post Link to post Share on other sites
raewyn22 149 Report post Posted July 27, 2013 your talking about a facelift right? I have no idea what the setup for a prefacelift is. hmm im sure that there should be plastic bungs for want of better word that is pushed in the valance regardless of if fogs or blanks. i dont have an E30 in the drive to jog my memory sorry! Definitely facelift, have posted a photo for reference. Andy, sounds like you need to get back into the E30 club Quote Share this post Link to post Share on other sites
raewyn22 149 Report post Posted July 27, 2013 Uploaded with ImageShack.us Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted July 27, 2013 Definitely facelift, have posted a photo for reference. Andy, sounds like you need to get back into the E30 club you bet I do. Secretly looking for a tidy silver tech1 Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted July 27, 2013 you bet I do. Secretly looking for a tidy silver tech1 *tech2 Yeah the fog lights screw into plastic bungs if you line it up behind the valance the holes should line up to plastic screw bungs and you just need some screws to mount them. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted July 27, 2013 *tech2 Yeah the fog lights screw into plastic bungs if you line it up behind the valance the holes should line up to plastic screw bungs and you just need some screws to mount them. *either was starting to think i was going cray, good another E30 dude agreeing with me! Raewyn not sure why your setup is different!? Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted July 28, 2013 Hey guys, Any particular types of clips or screws to be used when mounting the fog lights for the e30 on the factory mounting points? Car had blanks on it held on by rubber clips. All suggestions appreciated Thanks you will need the bungs+ screws, local wrecker, or if you get stuck there is a car here that they can be removed from Quote Share this post Link to post Share on other sites
raewyn22 149 Report post Posted July 29, 2013 Thanks every one for the help, ended up getting some clips of HellBM and self tappers to screw in... But what came out were two sided rubber/plastic clips. Got them in now, best thing I have done to it in months :-) Quote Share this post Link to post Share on other sites
