martyyyn 102 Report post Posted August 5, 2013 Mine wont cycle through the cd's when inserted and says 'NO DISCS' on the mid. Quote Share this post Link to post Share on other sites
Neal 576 Report post Posted August 5, 2013 If you have a spare hour or so they are easy enough to sort. Typically it will either be that the loading cog needs adjustment or just needs a good lube with lithium grease on the metal services that move together. The other issue is the laser which can fail over time which can be brought on ebay, but most of the time it's just either of the two items above. The link below will show you who to get it apart and check the loading cog adjustment. While it's apart put lithium grease on the loading surfaces. https://blogs.oracle.com/miko/entry/cd_changer_repair Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted August 5, 2013 what have you bought mate.Still got the e34? Quote Share this post Link to post Share on other sites
martyyyn 102 Report post Posted August 5, 2013 Hi Paul, No, the e34 is going nowhere. I bought a 2001 530i to replace the Focus. Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted August 5, 2013 available, in car and works tested all ok Quote Share this post Link to post Share on other sites
