cytamen 1 Report post Posted August 6, 2013 Sorry if I haven't searched the forums enough for an answer, but I have one of the 2 button Siemens keys with remote unlocking After replacing the batteries a couple of years ago, not knowing that you have to be quick to not require a reinitialize, I had to go to the dealer to recode them. I only brought 1 key with me which went through the laundry and is now out of action, so I need to reprogram the second key which is identical. The dealership essentially just got in the car, held down a few buttons on the key and got it working. I found online a few variations on how to do this which mostly say: Get in the car, sit down, close the door, put the key in and turn it to "1" for a couple of seconds (not more than 5), then take out the key. Hold down unlock for a few seconds and while holding, press lock 3 times and let go of both buttons.. I have done that, and the LED flashes for about 10 seconds on the key but then nothing. Has anybody done this before who can tell me what I'm doing wrong or is it back to the dealership? Thanks! Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 6, 2013 (edited) You forgot the final stage... push the unlock button while the LED is flashing. Car should lock & unlock Edited August 6, 2013 by *Glenn* Quote Share this post Link to post Share on other sites
cytamen 1 Report post Posted August 6, 2013 You forgot the final stage... push the unlock button while the LED is flashing. Car should lock & unlock Ta, I *think* I tried that, but I'll give that a try soon! Quote Share this post Link to post Share on other sites
sp8s 1 Report post Posted August 6, 2013 I had to do this as well a while back. Took me a few goes at it. Finally worked when I put the key really close to the mirror, just about touching. Quote Share this post Link to post Share on other sites
cytamen 1 Report post Posted August 6, 2013 Awesome, finally got it to work after combining both suggestions, thanks a million! Quote Share this post Link to post Share on other sites
