lord_jagganath 421 Report post Posted August 21, 2013 (edited) Car: Model:E34 Touring Year:1996 Vin number:WBAHJ62020GD13364 Import / NZ new: NZ New Options ie:Auto, Climate control Airconditioning? very low on options? I am experiencing some smells in the cabin, burnt fuel and oil, only when the A/C is on. After some searching, the general diagnosis points to faulty:- 1. Fuel pressure regulator/switch 2. Oil pressure switch 3. EVAP system 4. Valve cover gaskets 5. Dirty oil (probably needs an oil change) 6. Fuel filter 7. MAF sensor dirty 8. lambda/o2 sensors 9. PCV Valves 10. Air filters 11. fuel injector, 12. fuel system leak. 13. Bombed Catalytic converter -hence the Decat. Am going to see if I can pinpoint the issue soon. First, I will reset the ECU by unhooking the battery and will update tomorrow. Thank you. Edited August 21, 2013 by The Juggernaut Quote Share this post Link to post Share on other sites
Phil-540i 166 Report post Posted August 21, 2013 Hiya Given its a new toy, less donuts or less times around roundabouts 'checking its handling' might = less dizzy.....??!! On a serious note though, given its a hearse / wagon version, any chance rear door isn't sealing properly on its seals......maybe ingesting into cabin that way?? Seems weird it's only doing it with air-con going though...... De-cat - absolutely!! Same's gonna happen to mine (& a few other mods to make it sound like it should, rather than as it does....... ) Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted August 21, 2013 its anti freeze you have the leaky joints of the pipes into the heater core. Quote Share this post Link to post Share on other sites
lord_jagganath 421 Report post Posted August 21, 2013 Paul, how can I determine that to be the cause? I suppose I ought to check coolant levels every morning. Anything else? After 250k clicks I suppose the Cat has stuffed up? Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted August 21, 2013 Paul, how can I determine that to be the cause? I suppose I ought to check coolant levels every morning. Anything else? After 250k clicks I suppose the Cat has stuffed up? The leaky heater core is a classic e34 problem.The antifreeze has a particualr smell,and you may have some slight fogging of the screen when you think you shouldnt.The a/c clears it tho.The leak is very slight.Cant help re the cat i didnt have one Quote Share this post Link to post Share on other sites
lord_jagganath 421 Report post Posted August 21, 2013 (edited) ^ come to think of it, the windscreen did fog up in the centre when the a/c was off. So does this mean I need to replace the heater core? (egads! ) or are there any other options? Edit: http://forums.bimmerforums.com/forum/showt...IHKA-content%29 oh hey, here's the DIY guide. Looks like I could plonk in an OBC and a stock CD controller in her at the same time, nice. Edited August 21, 2013 by The Juggernaut Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted August 25, 2013 (edited) The heater core doesn't look too bad to do on these. it's about $300 us or something to get from Pelican. but you need to eye-ball it to make sure it's the right kind. Does it have a catalitic? mine doesn't. Edited August 25, 2013 by antil33t Quote Share this post Link to post Share on other sites
lord_jagganath 421 Report post Posted August 25, 2013 ^ I am assuming it does, as it is an NZ New car from 1996, I suppose the only way to check is through the VIN or visually inspecting the bottom of the car. Quote Share this post Link to post Share on other sites
Phil-540i 166 Report post Posted August 25, 2013 ^ I am assuming it does, as it is an NZ New car from 1996, I suppose the only way to check is through the VIN or visually inspecting the bottom of the car. Remembering that assumptions are.............. Crawl under for a look I reckon, as even if it did have one, might have been previously removed........ Cats are overated - whole exhaust,including cat 'fell off' my ute - V8 turbo diesel sounds very 'unToyota' now that its breathing through a 3 inch system.......(Cracks me up as my Toyota dealer being REALLY queer & pedantic won't give it a wof, yet VTNZ does no problem......) Quote Share this post Link to post Share on other sites
