Philip 0 Report post Posted August 23, 2013 Headlining has started drooping on my e36 coupe with sunroof. I'm all for fixing it myself, but I don't know where to get the material, I've searched the forum but couldn't see a shop mentioned. Needs to be black, 3mm foam backed preferred, unless anyone has a better recommendation on material choice. Auckland please Will use 3m 90 spray adhesive, or try get 3m headliner & fabric spray adhesive Quote Share this post Link to post Share on other sites
M3_Power 636 Report post Posted August 23, 2013 I saw this company in the classic car magazine once ... no idea if they are any good or have the fabric you are after - but apparently comes highly rated from some quarters I've heard. Unfortunately not Auckland based. http://lemansautofabrics.co.nz/headlining-bmw.html Quote Share this post Link to post Share on other sites
Philip 0 Report post Posted August 23, 2013 Just called them, they reckon 45buck per meter plus gst. And I would need 2.5 meter. Plus postage to Auckland So approx $150 for material plus p&p, then another 90 or so on glue hmmmmm Quote Share this post Link to post Share on other sites
jom 98 Report post Posted August 23, 2013 Philip said: Just called them, they reckon 45buck per meter plus gst. And I would need 2.5 meter. Plus postage to Auckland So approx $150 for material plus p&p, then another 90 or so on glue hmmmmm And don't forget the 2 days sanding off all the old foam and glue. Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted August 23, 2013 Jo M said: And don't forget the 2 days sanding off all the old foam and glue. Took me about 30 min to remove liner and residual foam. Once it starts drooping it almost removes itself. Just wish I'd made a better choice with the fabric Quote Share this post Link to post Share on other sites
Philip 0 Report post Posted September 10, 2013 Got some 3mm foam backed material and bostik supertak spray adhesive and retrimmed my headliner a few days ago. ... Looks brilliant! I'm very happy. And that sunroof interior panel was a bitch to figure out, but it can be removed without removing the complete sunroof cassette. Will get up some pics at some stage Quote Share this post Link to post Share on other sites
Young Thrash Driver 1021 Report post Posted September 22, 2013 Please do, Phillip. I'm in the same boat as you, and summers just around the corner- won't take long with the windows down and it'll be at head level! Quote Share this post Link to post Share on other sites
