DarkRepuls3 0 Report post Posted September 10, 2013 Just brought a e36 320i 1994 off trademe. However, when I drive at high speeds and brake at high speeds there appears to be a wobble or like a jolt in the car? Does anyone know what could be causing this? Or what I need to get fixed? Thanks Quote Share this post Link to post Share on other sites
allan 295 Report post Posted September 10, 2013 (edited) Have you checked the common things out of round tyres, wheels any thing loose if so then maybe you have Warped rotas, worn suspension bushes control arms etc, Edited September 10, 2013 by tim 325 Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted September 10, 2013 More than likely unbalanced wheels, bearing, alignment! Quote Share this post Link to post Share on other sites
2052NV 43 Report post Posted September 10, 2013 get front wheel balanced and while the wheels are off get discs skimmed if there is enough meat left on them.... and that should be problem solved Quote Share this post Link to post Share on other sites
Ultrarandom 3 Report post Posted September 10, 2013 I know a common cause for this is the lower control arm bushes in the front. But start off with the easy basics, doesn't hurt to replace things or get a wheel alignment/balance. Have the same problem in the girlfriends car. Quote Share this post Link to post Share on other sites
Cab 148 Report post Posted September 10, 2013 I'd go with control arm bushes Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted September 11, 2013 If it's just braking at high speed most likely the brake disks need skimming or replacing (and new pads). If it's noticeable when you're not under braking could be wheel alignment or control arms/bushings. Quote Share this post Link to post Share on other sites
