thorburn
Need to get my project going before I loose all hope
I hacked my wiring loom up. It's taken me this long to man up and decide it isn't worth rewiring the whole car. So I need the body loom of the car with all the connectors.
And some window winder motors. Because I was dumb and thought manual windows would be a good idea
I did the exact same thing as you.
Not sure if its an option for you ... but I ended up wiring up the windows with heavy duty after market rocker switches with fuses, plugs for the doors etc. Way easier than trying to splice in the OE wiring if you've already taken it out.
Edit: I re read your post and see you want a whole new one. Ignore the above then!
Edited by Steve K-B
Cheeers Steve. It is still useful because I was still going to do away with the body ecu
Sweet, Let me know if your heading down the reverse polarity switch idea then. I went through a couple of switches before I found a good one that could handle the current.
