Ace Of Spades
Help e30 dash not really working..
I have no idea whats up, but on my way to work on saterday this happend...
Help??
http://s1122.photobucket.com/user/Sam_E30/media/IMG_0463_zpsd7a7f24a.mp4.html
http://s1122.photobucket.com/user/Sam_E30/media/IMG_0464_zpsf9f51888.mp4.html?sort=3&o=1
Edited by Ace of Spades
Is the temp gauge not working either??
SI Board Battery will probably be dead / leaking / corroding the circuit board.
I do have a pic of how I bypasses the SI Board, but I think mine was a motometer cluster, so not sure if it will work on a VDO one.....
Every thing bar the speedo is not working... even the lights to tell you how many kms before next service.
Dose it do anything like what mine done? http://www.youtube.com/watch?v=Vcn-I9-I1AE
If so i had a short between two wires running down past the shifter boot
These two
Those two wires were blowing fuses as well, 2 30A fusses, cant remember what ones they were.
I insulated the wires, replaced the fuses and all was good again.
Not to sure if youre problem is the same thing but its worth a shot i guess
Can you please elaborate on this? not to sure what an si board is..
These two
Ive had a look around and cant find anything but will look again, cheers mate
when you say they heater doesnt work, do you mean the fan? or are you not getting temp?
No fan at all, no noises or anything
hmm, guessing you checked all fuses etc as a place to start?
The Service Indicator Board - pretty Xmas tree lights in the dash that tell you the oil needs to be changed.
It has rechargable batteries, these die / leak / make a big mess often and the board/batteries need to be replaced (or bypassed) for the dash to start working again.
Pelican have a write up here
Search the net a bit more and there will be heaps of pics also.
Cheers mate will have a dig around the web
Also if there's any auto sparkies or people who kinda know what there doing, i will provide plenty of cold ones for you time/expertise
