rowans17
Whine Noise from turbo
Excessive whine will either indicate failed turbo bearings or damaged vanes. Both of these cad cause the vanes to rub on the cold side housing causing the whine. However, If there's whooshing with it, I'd suspect normal turbo whine, with one of the intercooler hoses failing under boost. I've had this before in a Subaru. It would also account for bov sound as your car should have a bypass valve (plumbed back bov) from the factory.
  • Like 1
This is what I'm leaning towards..there is still the same old turbo whine noticeable, it is just overshadowed by the whooshing. As best we could determine it sounds like it's coming from the turbo area; is there a commonly failing pipe in that area?
boost leak test it. should be done whenever you pull the system apart / reassemble it.
