hybrid 1045 Report post Posted December 7, 2013 Fits: E46 3-series, '99-'06 330/328/325/323 and Z3 3.0/2.5 Will probably fit e39's M54 engines as well .. but don't quote me on that. Had these stashed away for a while and forgot I had them. Moving house .. grab em before I move and end up in a box and I forget about them again Yours for $150 (Pulleys only) First in takes em. UUC Blurb UUC Motorwerks Ultimate Under Drive Pulley Set When you bought your BMW, you paid for a lot of horses... but are some of them stuck in the corral? Take back that lost horsepower! A car's engine does many things other than just making the car move. Power is used to run the various accessories... things like the water pump, power steering pump, and alternator. All of these use horsepower, horsepower that is lost. Power that could be making the car faster. Each accessory uses rotary power - each accessory is turned to perform it's function, whether it's an electrical component (the alternator) or a fluid displacing component (the water pump and power steering pump). They all have a pulley which takes power from the crankshaft pulley via a belt. Some of the engine accessories take more power than they really need, dramatically affecting engine performance. Like an overprotective parent setting a curfew, there is a very big safety margin built into many systems of a BMW, especially in the accessories. Driving these accessories at higher rpm is a waste of energy, running it at a much higher rate than it needs to for optimum effectiveness. This is energy which could be put toward acceleration instead. What's an underdrive pulley? An underdrive pulley is a replacement accessory pulley that bolts up the same as stock, but has a different size (ratio) and material specifications intended to free up lost horsepower. By increasing the diameter of each accessory pulley, the speed at which the accessories are turning relative to engine RPM decreases. Does this actually make horsepower? Underdriving the accessories does not add power to the engine, it frees up the power that is normally wasted on overdriven accessories. The theory is that a larger pulley will drive the accessories slower thus reducing their parasitic horsepower loss. No more power total, but more power sent to the wheels. As an additional benefit, the reduction in wear (less usage) on the accessories due to the lower duty cycles can extend the life of these parts. However, a look at each pulley-driven system under the hood will tell you why it isn't as simple as "just a bigger pulley". Which accessories can I underdrive? Of the four accessories that can be underdriven with a larger drive pulley, one is electrical (the alternator) and two are fluid pumps (the water pump and the power steering pump). The fourth is a compressor (the air conditioning unit). UUC Motorwerks Ultimate Underdrive Pulley set provides replacement pulleys for the water pump, power and steering pump. Please see the "Technical Details" page for more information. What abut the weight? WARNING: Some companies have been marketing replicas of UUC's original pulley design, but advertising them as superior due to "light weight". This clearly shows these replica manufacturers do not have an understanding of the underdrive concept... weight reduction is not a factor in producing power with underdrive pulleys... the gain comes from reducing the accessory speed, not from less rotating mass. While some pulley advertisers do advertise "lightest weight", we feel that to be somewhat deceptive... in our extensive testing, we have proven that the actual weight of the pulleys is not a factor in increasing power gains whatsoever. Each pulley itself weighs just a few ounces... shaving off a small amount of additional aluminum will not make one single bit of measurable power. Weight savings in a BMW that are important are in the much larger rotating components such as a lightened flywheel or lighter road wheels. Why does UUC offer accessories pulleys instead of a replacement crankshaft pulley? At UUC Motorwerks, our goal is improvement of the total performance envelope. We don't want to provide a product that is only appropriate to some cars and some circumstances. By using an underdrive system based on the accessory pulleys, UUC has the ability to fine-tune the specs of each pulley. None of the accessories on your car have identical operational parameters, why should the pulleys that drive them? The practice of removing your engine's crankshaft pulley in order to replace it with one of a smaller diameter does have a place in the performance tuning dictionary. However, it is important to note that the primary benefits from this modification are due to the decreased weight of the replacement crankshaft pulley. Regarding the underdrive effect, all the accessories see the same change in RPM - no fine-tuning available. The price for this gain is the loss of the tuned elastomeric harmonic damper. The crankshaft on your inline six is subject to a wide variety of vibrations and harmonic phenomenon. Could UUC have designed a replacement crankshaft pulley to our satisfaction? Absolutely. But then we'd have no way to recommend one of our favorite performance modifications, the lightweight flywheel Quote Share this post Link to post Share on other sites
dreadful1 7 Report post Posted December 7, 2013 AHhh!I was looking for a set of these before but I have moved my interest from cars to an engine on two wheels now!this is such a bargain compared to getting them shipped in from the states!Anyway GLWS Josh Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted December 7, 2013 Cheers Yongxi Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted December 9, 2013 last chance before it goes in a box never to be found again Quote Share this post Link to post Share on other sites
aw-krazy 45 Report post Posted December 9, 2013 Arghghhhh if only it fit m52 engines :'( Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted December 9, 2013 So what would be the difference between the M54 and M50 pulleys then? 'Scuse the n00b question Quote Share this post Link to post Share on other sites
aw-krazy 45 Report post Posted December 9, 2013 Yeah id also be interested to know the difference Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted December 10, 2013 Im not sure ... here is a photo of my s50b32 if that helps. Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted December 10, 2013 (edited) Just to confirm, the pulleys are to suit E46 M54 engines? Wonder if the difference is in the V-ribs on the pulley itself Tempting to grab them and find out if they'll work on an old donk like mine Edited December 10, 2013 by Ahmedsinc Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted December 11, 2013 If I remember might check them up at rays tonight. Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted December 11, 2013 If I remember might check them up at rays tonight. Did you get these pulleys for your S50? Might be on to something here Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted December 11, 2013 No, is a hang over of parts from my old e46 330i I didn't install. Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted December 11, 2013 They look really similar to a m50 one. If you have them next time you are at rays can you check, and I will pay for them in bouncy cuddles. Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted February 5, 2014 Cheers Yongxi Still available? Even if hidden under a large pile of moving boxes? Quote Share this post Link to post Share on other sites
