e30ftw 433 Report post Posted January 4, 2014 (edited) Have an e30 manual conversion kit, includes the following; m20 Flywheel Clutch + Pressure plate and throw out bearing Getrag 240 gearbox and crossmember with new gearbox mounts, also with shifter linkage, rubber boot and shifter Driveshaft Clutch + Brake pedal Clutch reservoir and line Master and slave cylinders New pilot bearing Only bits it doesn't include is guibo and clutch pressure plate bolts Fit any facelift e30 m20, can fit pre facelift with center bearing change as long as it does not require bellhousing sensors. $800 ONO Edited January 5, 2014 by e30ftw Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted January 4, 2014 I have a tatty 1pc gear knob and boot I'll give you to include if you like Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted January 4, 2014 Sweet cheers, Flexible with price need to move it before I move months end don't want to be lugging these bits around Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted January 5, 2014 BUMP $800 ONO, Goes on trademe later this week Found the pressure plate now so has everything to do the swap minus a guibo and pressure plate bolts. Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted January 9, 2014 Bump b4 trademe Quote Share this post Link to post Share on other sites
Crankin 0 Report post Posted January 9, 2014 Where abouts are you? And what condition is the clutch in? Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted January 9, 2014 Wellington. Clutch looks good will get pics tomorrow. Looks like it has a fair bit of meat on there, still has the grooves or atleast one side does if I recall correctly. Will check and post tomorrow. Quote Share this post Link to post Share on other sites
Etwenty1 45 Report post Posted January 9, 2014 John, Have you sent my bracket yet ???????????????????????????????????????????????????????????????????????????????????????????????? Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted January 11, 2014 Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted January 12, 2014 Now on trademe.. Needs to be gone in the next 2 weeks. http://www.trademe.co.nz/Browse/Listing.aspx?id=684823676 Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted January 15, 2014 Bump!! Accepting reasonable offers Quote Share this post Link to post Share on other sites
Tidy30 38 Report post Posted January 15, 2014 Tempting! But I haven't looked into anything related to manual conversions yet. It is on my list... Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted January 19, 2014 BUMP finishes tomorrow. Somebody?? Quote Share this post Link to post Share on other sites
