charles28 141 Report post Posted January 8, 2014 I have installed my Mono block Amp and Sub into my E39, which works fine with a Line output converter. However I want to replace my front speakers with some DLS MS5A's I have spare (and tweeters), disconnect Mid range and run these off another Amp I have spare. I tapped into the Front Speaker Woofer Wiring for the LOC, but is this a Full range output? Ie will it give me full range? to run my Woofers and tweeters? using my aftermarket amp or will it be missing the high frequencies? The factory Amp appears to have 3 pairs of wires for each lot of speakers in the front. Cheers Charles Quote Share this post Link to post Share on other sites
Neal 568 Report post Posted January 9, 2014 Sounds like you might have a 10 channel Hifi amp with active front speakers. The part number of the amp can be googled to confirm. In which case the woofer speaker out it wont be full range. Some of the BMW tuners can be modded to give RCA unbalanced outputs giving a cleaner signal for adding higher quality amps and speakers. Could be an option for you. e.g. http://bimmersport.co.nz/topic/40554-e46-m3-stereo-build/?p=452632 Quote Share this post Link to post Share on other sites
