Tristan 338 Report post Posted January 13, 2014 (edited) http://www.trademe.co.nz/Browse/Listing.aspx?id=685303776&ed=true Inner diameter: 60mmOuter diameter: 75mmOverall length: 188mm Edited January 14, 2014 by Tristan Quote Share this post Link to post Share on other sites
M3_Power 636 Report post Posted January 14, 2014 Tristan Can you measure the ID and length of these for me please. Thanks! Quote Share this post Link to post Share on other sites
Tristan 338 Report post Posted January 14, 2014 Will have it up for you this evening, Tom. Cheers Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted January 14, 2014 Most interesting. Might come in handy! Quote Share this post Link to post Share on other sites
Tristan 338 Report post Posted January 14, 2014 (edited) Inner diameter: 60mmOuter diameter: 75mmOverall length: 188mm Edited January 14, 2014 by Tristan Quote Share this post Link to post Share on other sites
M3_Power 636 Report post Posted January 14, 2014 Inner diameter: 60mm Outer diameter: 75mm Overall length: 188mm Hmmmm interesting ... As a comparison, the E46 M3 tip is ID 61mm OD 65mm L 121mm I wonder if it'll fit the E46 M3 muffler if cut down to be shorter .... Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted January 14, 2014 Hmmmm interesting ... As a comparison, the E46 M3 tip is ID 61mm OD 65mm L 121mm I wonder if it'll fit the E46 M3 muffler if cut down to be shorter .... From memory when I last had some they are double walled so by cutting the end where the are crimped together they might fall apart unless braced together some other way Quote Share this post Link to post Share on other sites
Tristan 338 Report post Posted January 14, 2014 Tomorrow I'll take some photos of both ends so you can see what the internal structure is like. Quote Share this post Link to post Share on other sites
qube 3571 Report post Posted January 15, 2014 just out of curiosity, will there be a big or significant difference by swapping these into a e46 m3? Quote Share this post Link to post Share on other sites
Tristan 338 Report post Posted January 15, 2014 (edited) just out of curiosity, will there be a big or significant difference by swapping these into a e46 m3? In terms of what? Fitment? Sound? To clarify these are just tips so don't affect sound. The fitment, I can't be sure. Need any measurements? Edited January 15, 2014 by Tristan Quote Share this post Link to post Share on other sites
