M3AN 4188 Report post Posted February 27, 2014 Thanks Mark, is that 20% discount for Bimmersport members? Quote Share this post Link to post Share on other sites
M3AN 4188 Report post Posted April 11, 2015 (edited) For future reference the required bolts (S50B32 VANOS) are a little different to those listed previously. What is required, all in high tensile 12.9, Zinc plated steel is: 6 x M5 x 16mm (intake piston cover) 3 x M6 x 20mm (exhaust piston cover) 8 x M5 x 20mm (4 each for the intake and exhaust solenoid covers) You also need washers for each of the above and the washers can not have an OD > 1mm more than the bolt head diameter (i.e. they must be small Outside Diameter washers). The washers do not need to be hardened which makes it easier to find suitable ones. The 9 perimeter bolts are custom sizes but do not need replacing, they are not included in the list above and I haven't measured them. Edited April 13, 2015 by M3AN Quote Share this post Link to post Share on other sites
M3AN 4188 Report post Posted May 28, 2018 All pics and links finally updated. No thanks to Photobucket or Dropbox! 2 Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted May 28, 2018 did not expect this.. 1 Quote Share this post Link to post Share on other sites
