gjm
(Up to) 5,500bhp 12-rotor engine dyno tested
Length: 30″
Width: 31″
Height: 24″
Weight: 830 lbs
Displacement: 960 cubic inches
Max Wide Open Throttle RPM: 8,500-9,000
So shiny. So many rotor tips to replace...
More info here and at www.12rotor.com
Now THAT would be nice in my E36 :lol:
Not really that impressive.
Would expect better from 960 cubes.
Naturally aspirated (pump gas 87 octane) 1,440 hp pleasure use at 400 hours.
Turbo-charged 10 lbs boost (pump gas 87 octane) 2,400 hp poker run version at 200 hours.
Turbo-charged 25 lbs boost (race fuel 110 octane) 3,600 hp race version at 30 hours.
Turbo-charged 50 lbs boost (race fuel 116 octane) 5400 hp Drag race version at 11,000 rpm
Edited by bellicose
Christ - it's physically bigger & heavier than a std big block Chevy! And if you start talking Donovan, Merlin, Dart or Keith Black, then you're up in the same power range with less weight again.
Hell, a Teague Marine 1365 hp engine even comes with a 12 month warranty! And thats only 565 cubes! I too would expect more from nearly 1000 ci.
