GeorgiePie 1 Report post Posted March 15, 2014 (edited) Hey guys, I have some aftermarket headlights installed on my E39 Touring, took it in for a WOF at the local VTNZ and it failed due to the indicator bulbs in the headlight not being secure....they were taped in by previous owner! Is there some sort of easy fix i can do for this eg harness or bulb holder that will plug direct into the wiring harness that im already running? Im not running HID, Keen to get this sorted asap, would i need to get intouch with Miland or do some diy - which id like to avoid. Open to suggestions though Thanks. Edited March 15, 2014 by GeorgiePie Quote Share this post Link to post Share on other sites
Young Thrash Driver 1021 Report post Posted March 15, 2014 I think the last owner already used the easy fix Quote Share this post Link to post Share on other sites
GeorgiePie 1 Report post Posted March 15, 2014 Ahhh...im sure i can make a bracket up however there must be a part im just unsure where to look or who to ask I'd rather keep it clean and tidy then rough. Quote Share this post Link to post Share on other sites
allan 295 Report post Posted March 15, 2014 Have a look in the parts cat Realoem.com under headlights should show you something Quote Share this post Link to post Share on other sites
GeorgiePie 1 Report post Posted March 15, 2014 Looks like i need this part here, surely someone will be able to supply this in NZ? http://www.ebay.com/itm/BMW-E39-540-528-M5-Bulb-Socket-For-Front-Turn-Signal-GENUINE-BMW-/170726247135 Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted March 15, 2014 First you need to confirm the type of bulb you need. In NZ P21 (clear) or PY21 (amber bulb) are common bayonet fittings but have different internal codings so you cant accidetally use the wrong bulb. Then there is the bulb socket to housing coding which is sometimes different to stop you putting a stop bulb in an indicator lamp etc, etc. The bulb socket you linked on ebay looks to be a P21W (wedge base). It is a genuine Hella part, but it is common to have different bulbs for different markets - & that sellier looks to be american. Suggest talking to Ray or Brent for a spare from a wrecked car. 1 Quote Share this post Link to post Share on other sites
GeorgiePie 1 Report post Posted March 16, 2014 First you need to confirm the type of bulb you need. In NZ P21 (clear) or PY21 (amber bulb) are common bayonet fittings but have different internal codings so you cant accidetally use the wrong bulb. Then there is the bulb socket to housing coding which is sometimes different to stop you putting a stop bulb in an indicator lamp etc, etc. The bulb socket you linked on ebay looks to be a P21W (wedge base). It is a genuine Hella part, but it is common to have different bulbs for different markets - & that sellier looks to be american. Suggest talking to Ray or Brent for a spare from a wrecked car. Thanks elmarco, The bulb type i have currently is a PY21 amber bulb - bayonet fitting. Would it matter what type of bulb i have as to what i need in terms of fitting it to the headlight? My biggest problem is getting the fitting into the rear of the headlight so that the indicator bulb and fitting are secure. Are Ray and Brent under different usernames? Thanks again Quote Share this post Link to post Share on other sites
allan 295 Report post Posted March 16, 2014 You can get in touch with Ray, forum sponsor want to buy section Hellbm Brent bmworld.co.nz 1 Quote Share this post Link to post Share on other sites
