*Glenn* 856 Report post Posted March 30, 2014 I saw this on a Motorhome forum and thought it may help some of you with your DIY removal jobs. It might work on wrap jobs too- maybe Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted March 31, 2014 Was fully expecting to see someone throw a brick at the window but that actually seems good. I meed to redo my rear window and am cautious about peeling the demister lines off Sent from my GT-I8160L using Tapatalk 2 Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted March 31, 2014 we use a similar technique at work to remove asset tags, except just use a regular hair dryer. glue would be as strong as that tint glue probably. might be worth trying befire you buy a steamer???? never would have thought to use it for tints, i might try it on my van at some stage, its all wrecked Quote Share this post Link to post Share on other sites
Surge 1 Report post Posted April 7, 2014 When we are removing tints at work we use a heat gun to initially get the film off (heat on the outside of the window, moving it around regularly making sure not to get it too hot) and then a solvent on the inside to the remove the glue - which keeps the demisters safe. It's a painful job at the best of times! Quote Share this post Link to post Share on other sites
