Guest Andrew
Visual Basic Geeks -I need help
Guest Andrew
Writing some software at work -
It basically converts a comma delimited file to a simple HTML table -
but in VB6 the farking Print command does a newline each time it runs - which is creating a very ugly table.
Option Explicit
Private Sub Form_Load()
    'Dimension Variables Needed
    Dim str_comma As String
    Dim strcomparing As String
    Dim int1 As Integer
    Dim firstrun As Boolean
    Dim x As Long
    Dim sTemp As String
    'Set varible value
    firstrun = True
    str_comma = ","
    'Open files for read and write
    Open App.Path & "\premiumstock.html" For Output As #1
    Open App.Path & "\stock.csv" For Input As #2
    While Not EOF(2)
        Line Input #2, sTemp
            If firstrun = True Then
                Print #1, "<font face=""Tahoma"" size=""1"">"
                Print #1, "<div align=""right""> <table border=""1"" cellspacing=""1"">" 'width=""100%""
                Print #1, "<tr>"
            Else
                Print #1, "</tr> <tr>"
            End If
        Print #1, "<td width=""7.14%"">"
        For x = 1 To Len(sTemp)
            strcomparing = Mid$(sTemp, x, 1)
            int1 = StrComp(strcomparing, str_comma, 1)
            If strcomparing <> str_comma Then
                Print #1, strcomparing
            End If
            If int1 = 0 Then
                Print #1, "</td>"
                Print #1, "<td>"
            End If
            firstrun = False 'change condition to end tables correctly
        Next
    Wend
    Print #1, "</tr>"
    Close #1
    Close #2
    End
End Sub
Suggestions?
When you go through the loop dont print each 'field' to your html, concatenate them to a temp string.
Once your loop has finished concatenating each field print the line out in one go.
Guest Andrew
cheers - will give that ago.
I'm finding VBs text handling extremely poor compared to python or C. Now that I look back on it - I could of done this in python even hah.
syntax for concat in VB?
Guest Andrew
For all of you
it is generating code like
<p align="center"><img border="0" src="PWA_logo_2col.jpg" width="640" height="172"></p>
<html>
<head>
<title>Premium Wholesale Auctions LTD - Dealer Wholesale List. Updated 21/10/2005</title>
</head>
<body>
<font face="Tahoma" size="1">
<div align="right"> <table border="1" cellspacing="1">
<tr>
<td width="7.14%">
S
t
o
c
k
</td>
<td>
Y
e
a
r
</td>
<td>
C
etc
Guest Andrew
Martyn - found an easier solution.
Occured to be as I was skiiming through a tutorial on OLD OLD BASIC
Print does not add extra delimiters, but does concatenate a final CR/LF to each line. The CR/LF can be suppressed by ending the command with a semicolon (;). (This trick has been available in every Basic I've used, but it is not documented in the VB 6.0 Help.) Read it back with Line Input. (Line Input assumes a DOS type ASCII input file where each line is terminated with CR/LF. It does not recognize the unix line termination character.)
BADASS - good old semicolon saved the day.
