SavageXii 2 Report post Posted April 15, 2014 whats the difference between a e30 325 getrag 260 and a e34 535 gearbox?http://www.realoem.com/bmw/showparts.do?model=HD12&mospid=47382&btnr=23_0289&hg=23&fg=05 e34http://www.realoem.com/bmw/showparts.do?model=1412&mospid=47283&btnr=23_0293&hg=23&fg=05 e30would the be swappable or the components inside be compatible? and whats the difference? Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted April 15, 2014 whats the difference between a e30 325 getrag 260 and a e34 535 gearbox? http://www.realoem.com/bmw/showparts.do?model=HD12&mospid=47382&btnr=23_0289&hg=23&fg=05 e34 http://www.realoem.com/bmw/showparts.do?model=1412&mospid=47283&btnr=23_0293&hg=23&fg=05 e30 would the be swappable or the components inside be compatible? and whats the difference? different bellhousing so no go the distance between the top 2 bolt holes on a m20 ,m50 , m40 , m43 , m54 , m52 m44 s50 m47 etc etc are 140mm on a m30 m10 s38 s14 engine etc are 120mm yes some inside parts might be the same the getrags used behind say a 535i 635cso 735i etc may have bigger bearings , stronger gears etc ?? also you have early and late types different gearlever mechs , ones with cooling fins , ones with a place for crank sensors etc Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted April 15, 2014 I have a full 535i manual conversion also a large case lsd ( would have to check if the diff fits an e34 as it an e32 item ) Pm me if interested Quote Share this post Link to post Share on other sites
Driftit 2184 Report post Posted April 15, 2014 Isn't the E34 box a Getrag 265 and the E30 a 260? Could be different ratios. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted April 15, 2014 I have a full 535i manual conversion also a large case lsd ( would have to check if the diff fits an e34 as it an e32 item ) Pm me if interested e34 and e32 large case diffs are the same. only difference as if its from a v8 or 6cyl 12cyl model , different input flange Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted April 15, 2014 Isn't the E34 box a Getrag 265 and the E30 a 260? Could be different ratios. no both called 260 265 is know as the older dog leg box with the 1:1 top gear ratio , like used in some e30 m3 and older models like in some e28 M535i 528i e24 635csi etc but most have the 260 box Quote Share this post Link to post Share on other sites
